Just purchased an 00' DTS..need advice
Old Sep 7, 2006 | 01:06 AM
ZBrink's Avatar
Default Just purchased an 00' DTS..need advice
Hi guys I am new to owning a Cadillac and new to this forum. I just purchased a 2000 Deville DTS that I am picking up on Saturday. It will have 55K on the clock by the time I get it home. What should I look for mechanically and anything I should know right of the bat?? Thanks!
Old Sep 15, 2006 | 06:53 PM
Cadillac Man's Avatar
Default RE: Just purchased an 00' DTS..need advice
check the wires and the timing belt, get a tune up. also it needs to go through a 120 point check up. otherwise you'll be kicking yourself in the butt in the near future.
Old Sep 15, 2006 | 08:51 PM
FLCaddytech's Avatar
It doesn't have sparkplug wires or a timing belt.
If it runs good don't worry about a tune up till 100k miles.
These cars are great for letting you know if there is a problem.
If the cars computer picks up any low fluid levels or electrical or emmision problems a message will promptly apear on your dash.
Take it to a local dealer for an oil change.
They are great at checking your car over for potential problems.
If you feel they may be misleading you about something get a second opinion.
Otherwise search this site and you will find others with the problems they have encountered with there cars.
Hope this helps.
Old Sep 19, 2006 | 01:12 AM
Brolinger's Avatar
Pull up the rear seat and check the battery located under the right rear passenger's area. Be sure the battery is not leaking any acid. Check this frequently. I let it go on my '00 DHS (because it's a minor hassle to get to). My original battery got old, leaked like heck, and burned a hole clear through the floor pan. I could see the pavement underneath. What tipped me off was that I could hear the exhaust sound through the hole. I "fixed" it by gluing a sheet of plastic to the floor to keep out water, noise and exhaust. This is a common problem and there is a factory fix to the tune of $500 (they install a new floor pan liner in the well.) The Deville series and Pontiac Bonnevilles of that era both suffered from this problem. I suggest you replace batteries before they get too old and start leaking.
I love my DHS. I bought it new and have 80K now. The DHS and DTS are upscale versions of the standard Deville and worth the extra bucks for what you get.
gmanney
Aug 24, 2009 01:58 PM
Nah wutt
Nov 6, 2007 06:53 AM
jchutch
Jul 17, 2006 11:37 AM
danksontl
Jun 11, 2005 09:52 PM
