i need experts with northsatr cooling systems
Old May 31, 2008 | 11:47 PM
2thowEldoggHogg's Avatar
Default i need experts with northsatr cooling systems
I have a 2000 Eldorado ESC Northstar 4.6L V8. I want to know if I have damaged heads and or broken gaskets. Here is all I can really say. The coolent leaks through the hose attached next to the resevoir cap, because there is some sort of pressure in the cooling system. When the engine is cool, literally cool, I turn the car on so that the coolent can start circulating and quickly fill the resevoir tank all the way to the top as the coolent circulates then close it up. I notice some small bubbles, is that normal? The exhaust smoke is visible (I think it sort looks like steam) is that normal? I already replaced the thermostat with a 180F, and the resevoir cap as well. My fans only kick in for about 10 seconds after engine starts, is that normal? And how does my oil dissapear if there are no oil leaks????? I have to add a quart like aaproximately every 2 months. I NEED SOME REAL EXPERTS WITH THIS PROLEM PLEASEEEEEE
Old Jun 1, 2008 | 02:03 AM
NAFTA's Avatar
Default RE: i need experts with northsatr cooling systems
The oil part adding a quart every 2 months is normal on a northstar. The part where it burns coolant and you have steamlike smoke might mean you have headgasket troubles. I'm not an expert in this area so I can't diagnos anything for sure.
mycaddysoclean
Dec 22, 2012 02:43 PM
Matth3w
Apr 25, 2009 08:58 AM
cadillac carl
Nov 10, 2008 02:36 AM
modena35
Aug 21, 2008 09:27 AM
Vehicular Projects
Apr 1, 2007 07:22 PM
