How to question: pull the ignition lock cylinder out of the steering column
Old Jun 15, 2009 | 03:28 PM
llwta76's Avatar
Default How to question: pull the ignition lock cylinder out of the steering column
How do you pull the ignition lock cylinder out of the steering column? My only set of keys are so-o worn that they barely work anymore. Thanks for the help in advance! Larry
mod edit
title
Old Jun 17, 2009 | 12:30 PM
Chuwee's Avatar
You have to pull your steering wheel first then undo the turn signal switch and behind that you have a security screw that holds the cylinder in place. Remove the screw and pull the old cylinder out and replace in reverse order.
Now if you have a vat key you have to undo the wires from the harness connection under the dash and tie a wire or string to the cable before pulling the wire through the column. Then tie your new wire and pull back through the column and reconnect.
Old Jun 17, 2009 | 10:11 PM
let's not ignore the fact that the air bag will deploy ...
Old Jun 17, 2009 | 11:15 PM
Chuwee's Avatar
Not if you disconnect the battery and unplug the airbag...
Old Jun 18, 2009 | 06:56 PM
llwta76's Avatar
They had airbags in 1988??( Sorry, this is a '88 Eldorado)
llwta76
Aug 20, 2009 09:18 AM
GoldenCaddy
Aug 2, 2009 07:22 PM
simjack
Jan 7, 2007 10:29 PM
simjack
Sep 16, 2004 08:56 AM
