How to question: pull the ignition lock cylinder out of the steering column
How do you pull the ignition lock cylinder out of the steering column? My only set of keys are so-o worn that they barely work anymore. Thanks for the help in advance! Larry
........ mod edit title |
You have to pull your steering wheel first then undo the turn signal switch and behind that you have a security screw that holds the cylinder in place. Remove the screw and pull the old cylinder out and replace in reverse order.
Now if you have a vat key you have to undo the wires from the harness connection under the dash and tie a wire or string to the cable before pulling the wire through the column. Then tie your new wire and pull back through the column and reconnect. |
let's not ignore the fact that the air bag will deploy ...
Not if you disconnect the battery and unplug the airbag...
They had airbags in 1988??( Sorry, this is a '88 Eldorado)
