Help with1980cadillac Biarritz
Old Dec 16, 2012 | 11:16 AM
Deathangel's Avatar
Default Help with1980cadillac Biarritz
Hi I got a 1980 Cadillac Biarritz.368 motor,the motor is running supper rich ,shooting blue flames out of manifold pipe,I disconnect exhaust from cat .i changed plugs ,cap,rotor,wires,air gas filters,set timing at 10 degrees,checked all vacuum hoses,I can't figure out can anyone help Tim 973-349-4941 or email chopper1365@optonline.net please help
Old Dec 16, 2012 | 12:33 PM
Cadsforfun's Avatar
Default Carb./ DFI
Is you 368 the DF or the carb. version?? The DFI could be the prom chip in the computer, and the carb. version could be the float sticking . Map sensor , coolant temp. sensor, air temp. sensor are some other things that come to mind.
Rataz101
Aug 26, 2015 12:12 PM
gedarren_d
Eldorado Biarritz
Oct 6, 2007 10:09 AM
84CONV
Aluminum Block V8s
May 16, 2007 04:19 PM
tileguybysea
Mar 26, 2007 09:19 PM
MountainGoat
Apr 4, 2006 10:18 PM
