Heater not working 94 Concours
Old Nov 2, 2008 | 12:37 PM
lledrak909's Avatar
Default Heater not working 94 Concours
Gentlemen:HELP! My Dad's 94 Concours, 94K miles, is not giving us any heat. All controls seem to be working,air conditioning,defrosters, Auto,Economy etc. and the diverters all are directing air flow correctly. Is there a solenoid that might be causing this problem and if so where is it located?Thank you in advance for your kind assistance.Its getting colder here in N.J!
Old Nov 3, 2008 | 02:45 PM
Big5DoubleZero's Avatar
Default RE: Heater not working 94 Concours
Well there might be a bad heater control valve and/or clogged heater core...... check the coolant for any crap floating around before you go on to other things. The cold weather isn't that bad but thats coming from a Minnesotan.
Old Nov 3, 2008 | 03:34 PM
lledrak909's Avatar
Big5DoubleZero:
Thank you for your help. I am not Mr.Mechanic, so where is the heater control valve?? I also read on the website that it might be a door behind the glove box that could be jammed-A post said to remove the box liner (4 screws I think) but there is a sticker in the glove box warning about the air bag.Should I also check that? Many thanks again for your kind reply.
John
Old Nov 6, 2008 | 01:06 PM
No problem,you start somewhere like everyone else. On this car I do not know right off the top of my head where the heater control valve is. I would have to look on Alldata or Mitchell. If you have a library near by call and see if they do have Alldata at the location and you should be able to find it. The only thing is you might have ot fork out a few cents to print off the info.
On any literature you come across being web or book, check it out. I look everywhere I possibly can. The library might have a manual for your car also.
Alldata will give you a procedure of removing/installing things, especially if it has a SIR systeminvolved(Supplemental Inflatable Restraint system). Some things are so basic that there will be nothing on it for literature.
Old Nov 6, 2008 | 01:09 PM
Also to remind that the FAQ forum should be a big help if you decide to read more before you actually do post a thread when you think youare not sure on something.
Good luck
Old Nov 7, 2008 | 04:34 AM
lledrak909's Avatar
Big5DoubleZero: Not being a car guy I really appreciate allyour help and advice. I'll give it a try in the next few days. Again,many thanks.
fishnmachine
Nov 10, 2017 12:20 PM
mrdak
Mar 4, 2015 10:54 AM
haltomguy
Dec 11, 2009 01:11 PM
avenger
Oct 30, 2009 05:41 AM
Cadillac Kid
Nov 19, 2006 10:58 PM
