Head Gasket?
Old Oct 10, 2004 | 03:11 PM
angelgrace58's Avatar
Default Head Gasket?
I purchased a 1996 Caddy Seville SLS and 3 mechanics say it needs a head gasket. Is it worth it to fix it ? Can it be fixed? Or should I just put in a new engine? They say you don't know it's a head gasket or cracked block till you go and take 1/2 the engine apart which is hundreds of dollars just to diagnose. Car overheats but doesn't' show much other signs of head gasket. ANy suggestions?
Old Aug 13, 2007 | 07:03 PM
mvintson's Avatar
Default RE: Head Gasket?
i have heard so much about the whole labor part of it being a pain in the a@#, and that the head bolts always strip and it costs tons of money to replace. i do not reccomend buying a used motor cause you might end up in the same problem. if you have the money i know a crate engine will caust you around 3,500 not including labor and other parts. but in other words your going to have to spend a few grand anyway unless you sell the car or scrap it.
Old May 31, 2008 | 01:45 PM
Johnny's Avatar
I have the same problem with my 96' Eldorado. Northstar engine with 1003k on it.
Old Jun 3, 2008 | 02:24 PM
SilverFire's Avatar
The head bolts are designed to strip, they're a soft grade aluminum, so you need to buy the bolts every time you take the heads down.
For other signs, have you checked the oil and radiator fluid? You can drain those yourself and see if there's cross-contamination anywhere. I would also look at your exhaust, and see if there's any smoke coming during crank up, or fluid in the pipe, either black or clearish.
Does your car require the radiator tabs? If it does, those HAVE to be put in regularly according to the manual, because that can cause a head gasket failure if they aren't.
tomaxx313
Nov 25, 2007 01:50 AM
VIN9
Aluminum Block V8s
Sep 19, 2007 09:18 PM
nyblonde2004
May 18, 2007 10:23 PM
russell1337
Jul 1, 2006 07:30 AM
Jackie OH
Jul 22, 2005 09:43 PM
