cooling flush
Old May 7, 2008 | 01:35 PM
infan's Avatar
Default cooling flush
Have 01 STS Iam going to flush coolant system. I beileve I read some where to add some pellets, question is how many and is the lower hose the proper place to put them? thanks Jim
Old May 7, 2008 | 03:55 PM
Default RE: cooling flush
ORIGINAL: infan
two is all you need and bottom hose will do fine. maker sure it is the organic stuff, not metallic.
Its the same as the Gold Bar's Leak if the dealer dont have it.
You dont really need or should FLUSH unless you got crud and rust in the coolant system. You can simply DRAIN and refill.
Cadillac Allante FAQ
Sep 21, 2011 03:06 PM
greg2169
Apr 17, 2011 07:37 PM
Keith Carlson
Oct 19, 2010 06:09 AM
93ELDORADOETC
Apr 9, 2010 11:55 PM
jono6406
Feb 13, 2008 12:13 PM
