Catera: oil in coolant?
'97 Catera 64K miles
I have oil in my coolant resevoir. I use 1 quart a month. There is no water in the oil just oil in the water. I have flushed the radiator clean 3 times over 8 months. I also ran an expensive block sealer through the coolant system as well. I am quessing its an oil cooler problem.
Not sure. Any help out there? Thank you in advance.
I have oil in my coolant resevoir. I use 1 quart a month. There is no water in the oil just oil in the water. I have flushed the radiator clean 3 times over 8 months. I also ran an expensive block sealer through the coolant system as well. I am quessing its an oil cooler problem.Not sure. Any help out there? Thank you in advance.
Any techs out there with advice on how to tear into this oil cooler?
Help please. I have barely enough money to buy parts. I could use some helpful advice to r and r the oil cooler. Thanks in advance, Rich.
Cadillac-Catera
Jul 18, 2022 12:40 AM
cady97dev
Aluminum Block V8s
Mar 20, 2009 08:10 AM
