cadillac eldorad msg. "service ride control"
Anyone here being able to help me with a small problem concerning my 94 eldorado 4,6 l northstar? I´m living in Germany and the number of Cadillac specialists is very limited here and I do not have access to a proper manual to deal with this failure.
Following is shown on the display after engine start:"service ride control".
After checking out the bite module, the following failure messages are displayed: "S023 history, S060 history and S030 current".
So I have the following question: where are the applicable sensors installed?, how can I solve the problem and how can I probably change the devices? Up to now, I have no problems during operation of the vehicle, the suspension and steering systems seem to operate normaly.
Beside of these fault indications, I can say that I`m absolute satisfied with this car and its fine engine. Hope somebody can help me.
Thank You very much in advance
Ralf
Ralf
Thank you very much, will try this. One more question: where precisely are these sensors installed and how can I check them?
Thanks again
Ralf
Thanks again
Ralf
Last edited by ahlasack; Jun 15, 2011 at 03:14 AM. Reason: correcting typing error
Hello gmtechs, tried your advice. Could find no abnormalities, the problem still exists. Both heigh sensors front and the two lower shock strut sensors where in place. All plugs connected. Do You have an idea where can I find a list of all sensors with their respective identification/number(..S023 for example) and their installation position? Do You know, how I can possibly test the respective sensor? Any other Idea to solve the problem? Yours Ralf
here is a place for dtc http://myweb.accessus.net/~090/dtcobd1.html#cus
u need to take each plug out and measure the resistance in the sensor to see if it changes
u also need to check the other end power and ground
bsstyle2011
Mar 22, 2011 04:07 PM
throwaway2010
Jan 11, 2011 08:07 AM
andrew61987
Apr 23, 2010 06:41 PM
