antifreeze leak on the back of the block.
Old Nov 26, 2012 | 08:23 PM
Chad Maynard's Avatar
Default antifreeze leak on the back of the block.
1998 deville. I can smell antifreeze after it warms up but dont see it leaking. After it sits for a couple hours it starts to leak on the ground????? I can see small puddle on the top of the back of the block under the head area and in the valley. Ive seen it wet on top the heater control valve( I think thats what it is anyway). Drivers side of motor with big black motor on it. I havent taken a pressure tester to it yet. Ive looked at the crossover pipes a little bit on the back of the engine too. Those look ok. Nothing in the oil and exhaust looks ok. Any ideas on looking on the back of the motor?
I also having the fuel pump issue of not starting right away and after I shut it off it loses its pressure. From what I read its the valve in the pump. So I will need to find one of those too.
Thanks for all the help you can give.
Old Nov 26, 2012 | 08:25 PM
Does not overheat either.
alojdiradio
Apr 5, 2015 12:41 PM
albchilosoit
Mar 18, 2015 11:01 AM
bobbyking1988
Mar 15, 2013 11:07 PM
ondrece1
Sep 27, 2006 11:32 AM
BRYANT DAVIS
Nov 17, 2005 10:53 PM
