99 Eldo Fuel Pump Replacement
Old Feb 27, 2007 | 05:36 PM
zdld17's Avatar
Default 99 Eldo Fuel Pump Replacement
Hi guys,, had fuel pump replaced at the Caddy dealer as it was the quickest downtime. Is $700 out of line? Not to mention my towing fee. Car just reached the 85K mark.
Old Feb 27, 2007 | 06:02 PM
Katzmans Caddy's Avatar
Default RE: 99 Eldo Fuel Pump Replacement
I'm in Canada so you can adjust for exchange rates. When I owned a92 Bonneville3 years ago it was $750. I'd say the Bonny and the Eldo are comparable, probably the same darn pump. My mileage was about 135,000 km at the time so thats about 81,000 miles.
Old Mar 1, 2007 | 03:37 PM
zdld17's Avatar
Well, here I am again , scratching my head on what is going on now,,, Had $700 fuel pump replaced . Let car set out in front of dr's office for 45 min, came back to start it and motor started with a stumble then died. Tried 4 /5 times then motor stumbled back on to run. Drove a few days and same issue at lunch. I have replaced the underhood relay. I replaced the fuel filter again, still had pressure taking it apart. Wonder if fuel can drain back into tank while sitting?? Dealer did mention it could be a defective pump. But why? I am beginning to suspect the fuel bypass solenoid or what ever it is. Anybody ??
Old Mar 1, 2007 | 08:18 PM
You know I have found over the years that bad electrical connections are often the cause of these type of here today gone tomorrow problems. Check the sending unit connections. Check the fuel railconnections. It's a tough one.I'll think about it some more. Here in Canada GM guarantees work and OEM parts for one year after the work is done by their dealer. Take these guys to task. For $700 they need to get it right for you.
Old Mar 1, 2007 | 10:51 PM
Hey zdld17, do you know how to get the PCM codes from your DIS? That may help us figure it out. There is bound to be a code in there from stalling and stumbling.
Irish Whiskey
Dec 31, 2014 01:42 PM
FRANKO
Nov 7, 2012 04:11 PM
FilthyPhil
Feb 19, 2012 11:39 AM
May 14, 2011 12:04 PM
codye06
Jul 2, 2008 10:01 PM
