97 Deville..... Help!!!
Old Dec 29, 2007 | 05:09 AM
midsouth wholesale's Avatar
Default 97 Deville..... Help!!!
The car drives fine for about 5-10 minutes. Then, it all of a sudden shuts down! All of the lights on the dash light up like a Christmas tree! After it sits a while, it starts back up, may need a jump. Then repeats itself again. Any help provided is greatly appreciated!
Chris
Old Dec 29, 2007 | 08:26 AM
G.A.R.Y.'s Avatar
Default RE: 97 Deville..... Help!!!
Check all battery cable connections. How old is the battery?
After that, post results and we can go from there.
Old Dec 31, 2007 | 09:03 AM
jennifer5422's Avatar
Check for carbon build-up in the throttle body or the crank position sensors.
Old Dec 31, 2007 | 10:29 AM
ORIGINAL: midsouth wholesale
Chris
sounds like you are seeing a power down.
get it to a shop and check charging system, battery test UNDER LOAD.
I happen to like Sears for that ..
if all that is good, disconnect battery, reboot all systems and report back.
kmac171
Feb 20, 2008 10:36 PM
