97 Deville..... Help!!!
The car drives fine for about 5-10 minutes. Then, it all of a sudden shuts down! All of the lights on the dash light up like a Christmas tree! After it sits a while, it starts back up, may need a jump. Then repeats itself again. Any help provided is greatly appreciated!
Chris |
RE: 97 Deville..... Help!!!
Check all battery cable connections. How old is the battery?
After that, post results and we can go from there. |
Check for carbon build-up in the throttle body or the crank position sensors.
ORIGINAL: midsouth wholesale The car drives fine for about 5-10 minutes. Then, it all of a sudden shuts down! All of the lights on the dash light up like a Christmas tree! After it sits a while, it starts back up, may need a jump. Then repeats itself again. Any help provided is greatly appreciated! Chris get it to a shop and check charging system, battery test UNDER LOAD. I happen to like Sears for that .. if all that is good, disconnect battery, reboot all systems and report back. |
