96 STS hood Insulation
Old Jan 10, 2007 | 10:44 AM
vettenut's Avatar
Default 96 STS hood Insulation
Hey, Anyone know where i can buy the hood insulation for a 96 STS??? Thanks in advance.. Ron
Old Jan 10, 2007 | 06:04 PM
brougham1's Avatar
Default RE: 96 STS hood Insulation
Hey vette: Depends if you want to use and oem part. I have run across a really neat product called EZ Cool, it can be used under hoods, firewalls, trunks,etc. It is a closed cell foam coreproduct with fiberglass reinforced aluminum on both sides. It is easy to cut and fit and looks way more cool than standard insulation. Nascar uses it too. The material reflects temps. of 900 degrees, absorbs no moisture and deadens sound and vibration. The roll which is 4ft by 10ft run me about $60.00. Check with your local jobber to see if they handle it. By the way it is only 1/4' thick and 1 oz. per sq. ft......................
srxejrosenb
May 24, 2010 04:28 PM
vettenut
Jan 10, 2007 10:27 AM
trntyartist087
Sep 12, 2006 06:56 PM
CADDYMAN
Jun 25, 2006 11:58 AM
lovinmylac
Feb 16, 2006 05:35 PM
