95 deville exuast help
Old Apr 3, 2008 | 02:27 PM
glasstone's Avatar
Default 95 deville exuast help
any one changed the flange seal between the cat and the "Y" pipe that goes to the manifold? mine is leaking and I was wondering if this is an easy fix or normal fix or if there is a better alternitive. I get alot of gases in the cab while sitting still.
Thank you for your help in advance.
Rod
Old May 8, 2008 | 06:53 PM
Default RE: 95 deville exuast help
ORIGINAL: glasstone
Rod
assuming it is a bolt on flange, spray the bolts with penetrating oil, tap them with a hammer and then try to tighten.
Know that they may break. If it was me, I would cut the old bolts and install new bolt/hardware. Not hard, but is dirty work.
kmac171
Feb 20, 2008 10:36 PM
