95 air conditioner r/r
Old Apr 7, 2007 | 04:38 PM
STSSCOTT's Avatar
Default 95 air conditioner r/r
Hi All:
Before I start randomly tearing this 95 seville sts northstar down, does the air conditioner compressor come out from the top or bottom. Any tips on this. the bearing went in it.
Thanks
Scott
Old Apr 9, 2007 | 02:11 PM
belagatyo's Avatar
Default RE: 95 air conditioner r/r
Neither, it's gonna come out side way, through the right wheel well after removing a few splash shields.
Old Apr 9, 2007 | 03:58 PM
STSSCOTT's Avatar
ok, that's good news!! would you know if it is possible to remove the clutch assembly without disconnecting the lines??
Old Apr 10, 2007 | 03:20 PM
belagatyo's Avatar
You should be able to do it, but prolly need a special "removal tool". A workbench is just so much more comfortable...
Old Apr 10, 2007 | 09:44 PM
STSSCOTT's Avatar
does the whole clutch and pulley come off as one unit, and shoulkd there be a nut in the center holding the face plate on? because there is not on mine???
Old Apr 11, 2007 | 10:02 AM
belagatyo's Avatar
No nut (there, at least ), it's a key and press-it-on kinda thing.
Yes, the clutch plate and hub assembly comes off as one piece. The installer-remover is one tool (J 33013-B), and you can get/rent one from Auto Parts stores.
Old Oct 7, 2008 | 02:37 AM
groce45's Avatar
my 4.5 clutch& pulley are 2 pieces. pulley has snap ring.
gsteward
Aug 3, 2008 12:03 PM
h.fork
Sep 21, 2006 02:39 AM
brougham1
Jul 17, 2006 03:36 AM
brougham1
Jul 17, 2006 03:35 AM
gsteward
Jul 5, 2005 01:49 PM
