94 sls misses at low trottle....help.
Old Mar 14, 2007 | 10:58 PM
  #11
Katzmans Caddy's Avatar
Default RE: 94 sls misses at low trottle....help.
Backfire makes me think ignition system (coils are part of it) or timing.
Old Mar 14, 2007 | 11:30 PM
  #12
lyoung48's Avatar
I wonder how do you test the coils?
Old Mar 14, 2007 | 11:40 PM
  #13
I think the mechanic needs to isolate the cylinder(s) that are missing. He should have an engine analyser to plug into the computer. Once that is done then I would just replace that coil because the plugs and wires are new. Of course he should look at the plug again once he knows which one it is.
Old Mar 15, 2007 | 12:30 AM
  #14
lyoung48's Avatar
One of the issue's we have had is it doesn't do it all of the time. Oops, two things, It only does it under load.....one of those where you wish it would just break......
Old Mar 17, 2007 | 01:02 AM
  #15
Coils usually fail under load.
Old Mar 18, 2007 | 04:34 AM
  #16
when facing ignition issues, i usually dont bother with diagnostics since
such is time consuming and if you are paying someone, EXPENSIVE.
my approach is to replace all the standard stuff AND THEN see what i got:
plugs, wires, coils, ignition module, distributor cap & rotor, fuel filter, air filter,
(easy for me to say, i only have ONE coil .... )
and i also disconnect each injector and dielectric grease connectors,
clean the intake trottle, set timing, new drive belt, etc ...
also, my '88 has the capability to TEST each injector by way of the
dash D.I.C., so i do that also.
all that is really faster than testing at $90 / hour.
it is even cheaper.
ORIGINAL: lyoung48
Well, just my luck....Mechanic ran two different diagnostics and got no codes. Pulled, cleaned and checked connections, even wet the engine down to see if problem would jump out at him, no luck. He has another mechanic at a shop nearby and he is going to let him have a shot at it, see if he can isolate problem. If he cant isolate problem I am looking at replacing components to see if it fixes problem. I am not looking forward to writing the check on this issue......I am starting to get the image of a funnel that I am going to be pouring money in....It gets me that it only misses when running down the road in that 1100 to 1800 rpm range and the one time it backfired that was strange.
Old Mar 18, 2007 | 12:48 PM
  #17
[quote]ORIGINAL: Stealth
it is even cheaper.
[quote]
The 94 should have this capability as well, my 98 does. Good suggestion Stealth.
Old May 27, 2007 | 02:00 PM
  #18
lyoung48's Avatar
What bothers me about this issue is when you remove the EGR valve the problem dissappears. The problem points in this direction as if it is vacuum related. I cant fathom that I cant find a mechanic in Dallas that hasn't had experience with this problem on a Cadillac. I am getting real close to selling the car.....cheap.
Old May 31, 2007 | 11:29 PM
  #19
lyoung48's Avatar
OK, I spoke to a couple of Cadillac service people that said they had no experience with that particular problem. But, for $121.00 an hour they would take a shot at it......
Another thing that I have noticed is depending on the level of fuel in the gas tank the problem is worse. Also, Three times now the car has died when I have been stopped for a traffic light, light turns green, accelerate and turn left....No codes and no indication of a problem...It drives me crazy to, that you have to stop the car, put it in park before it will restart....
I really like this old car and hate to get rid of it....
Old Jun 1, 2007 | 12:32 AM
  #20
you dont give us much to go on.
we dont know what has been done,
low tank or full tank makes worse? which one?
insufficient data ...
however, lets see .. the posibilties.
EGR ?
low fuel / full tank? emissions fuel tank line?
M.A.P. ?
vacuum lines?
fuel filter?
coke buildup in throtle intake?
ISC ?
primary wires ? you did check engine compartment in the dark .. right?
distributor ? capacitor unit within?
u did check the firing order .. right?
cracked spark plug ?
whatever the case, its gonne be a $20 part ... bet on it!
coils rarely if at all, show failure at idle. under load or cold start, yes.
