93 deville heater problems
I have good hot heat blowing only on the passenger side only, it will change from vent to dash to floor no problem , but i get cold air blowing on the drivers side and into the back seat. are there to blend doors?? the cold air coming out of the drivers side has no hint of heat. passgener is toasty. HELP.
flipping thru the factory service manual I cant find nothing that would split the air from one side to the other. I could understand if the drivers side gave a hint of heat but there is none. Its like theres two heater cores , one for each side and my drivers side is clogged .
lenny lincoln
Mar 3, 2006 11:27 AM
