86 deville no fuel pressure
Old May 15, 2008 | 05:41 PM
curtsr's Avatar
Default 86 deville no fuel pressure
Greetings,
I recently removed the motor from a sedan deville to replace gaskets and seals. After putting everything back together, I now have no fuel getting to the engine. I have confirmed that the engine will run with gasoline placed directly in the intake stream, however I cannot get fuel pressure. My questions are as follows:
1) Where should I begin to look for apossible electrical connection that did not get made properly?
2) The fuse box doesn't have a label for fuel. Where is the fuse that controls the fuel pump?
3) Where is the relay that controls the fuel pump?
I have searched this site for some information, but nothing has helped. Since I drove the car prior to taking the engine out, I strongly suspect there might be an electrical connection that I have overlooked. Any help is appreciated. Thanks
Curt Sr
Old May 16, 2008 | 09:46 AM
Default RE: 86 deville no fuel pressure
ORIGINAL: curtsr
Greetings,
Curt Sr
before anything, even if it worked before, I be testing the fuel pump.
Apply direct power to it and see how it does.
The relay should be in one of the fuse blocks, possibly in the engine compartment or trunk.
xMikeDoex
Dec 20, 2013 08:10 PM
strabo40
Aug 8, 2012 02:55 PM
wsh777
Dec 2, 2011 09:08 AM
97Devile
Sep 12, 2008 04:15 PM
Z51
Aug 22, 2008 07:43 AM
