77 fleetwood lighting issues
Old Nov 22, 2010 | 07:28 AM
maverick9611's Avatar
Default 77 fleetwood lighting issues
i have no driving lights in low beam mode. high beam all 4 headlights work.
naturally i thought dimmer switch/ headlight switch. no dice, changed both out and still have same problem. i have the cadillac tech manual but its vague on this problem. can't be a ground due to all lights working on high. any thoughts?
Old Nov 27, 2010 | 02:02 AM
Fleetcoupe's Avatar
Hey Mav: Not sure if you have the guidematic headlights on the 77 models or not. If you do these guidematic lights have a relay and an amplifier assembly on them.Do you have any type of photo cell dimming feature or twilight sentinel??
Old Nov 28, 2010 | 06:01 AM
Default relay
ya i have twilight and sentinal. i swapped the guidematic relay with my buddies 78 eldorado and it did not fix the problem.i'm assuming sentinal is the high beam /low beam with sensor in grill. that works but the feature for turning lights off automatically does not work(twilight)i'm aware the sensor is in the dash/left side near window. will check that next
90allante
Cadillac Allante 1987 to 1992 Phase I & II
Mar 25, 2014 12:57 AM
Grant A. Van Vranken
Oct 26, 2013 06:21 PM
abaines12345
Jun 8, 2008 11:02 PM
Oct 8, 2007 11:34 AM
jankY22
Jul 11, 2005 03:36 PM
