1997 DeVille
Old Oct 10, 2007 | 08:48 PM
bfitz241's Avatar
Default 1997 DeVille
Hi. New guy here. I've got a 97 DeVille with aproblem. I checked the Tech and FAQ with no results, unless I missed something.
Anyway, the driver side mirror and rearview mirror no longer automatically darken. Driver mirror looks like a quantity of dark liquid has ac***ulated in the bottom of the glass. I have access to a Snap-On scanner [which I used to diagnose a failed MAF yesterday].As I scrolled through all the screens [no, I was never taught how to use it, my buddy plugged in it for me and said"enjoy yourself"] it said somethingabout a "Driver" being shorted. The only thing I could find on his Alldata was the power mirror memory module in the power mirror circuit. Think that's it? I'm going back to his shop in the morning to plug it back in and get better info. Now that I know about it, I want to fix it. Any help, ideas or explanations would be great.
Thanks
BF
Old Oct 10, 2007 | 09:24 PM
Default RE: 1997 DeVille
Unfortunely,your drivers mirror has died and will need to be replaced. I dont believe you can get glass separately. Rear view should have LED lit if its on,if not try to turn on or check for blown fuse.Hope it helps
Old Oct 10, 2007 | 11:01 PM
bfitz241's Avatar
Fuse you say.. I can handle that. There's no lit LED on the rearview. I will follow your advice and report back.
Just out of curiousity, what happened to the driver mirror to crap out like that?
Old Oct 10, 2007 | 11:14 PM
Katzmans Caddy's Avatar
Very common problem on a 10 year old cadillac. Once you start looking for a repalcement you will see how common a problem it is because they command nearly $200 used, close to $500 from GM. You'll need to make sure you get the dimming mirror. I believe your mirror has seapage, just old age. Best to get an entire assembly and paint to match so it is going to cost a bundle. Alternative is to buy a plain mirror from any auto parts store and glue over it... a solution that costs about 18 bucks!
Old Oct 11, 2007 | 12:52 PM
bfitz241's Avatar
OK, Checked the fuse, it's still good...I cleaned up the contacts in the fuse block just to be sure. Put the scanner back on it and couldn't find that "driver short" , said no codes though.
Any other ideas? or just live with it...
Old Oct 11, 2007 | 06:05 PM
What code is stored?Rear view, check connector for for power and ground. Connector should plug into mirror on windshield side of mirror.If power and ground are there rearview died too. Hope it helps
Michaelrj9
Nov 30, 2006 04:59 PM
bwickes
Oct 16, 2006 12:07 AM
1997caddy
Mar 2, 2006 12:18 AM
1997caddy
1997caddy
Mar 1, 2006 02:47 PM
