1996 Seville SLS overheating when driving over 40 mph and heater blowing cold air!
Old Mar 2, 2013 | 07:09 PM
  #11
AlexG's Avatar
Now i think about it last time i refilled with coolant I didnt have the fans on max heat when refilling, and didnt ask sealent tabs are those needed?
Old Mar 6, 2013 | 06:27 PM
  #12
AlexG's Avatar
any advice? noticed a small drops forming on bottom of engine and steam for about 30 seconds when I started after pressure test...any idea? Is it because I didnt put sealant tabs after last fluid exchange?
Old Mar 7, 2013 | 05:10 AM
  #13
proud american rider's Avatar
Could be. Since you have access to a pressure tester and you've seen steam out the exhaust try taking out all the spark plugs and pressure testing again for A few hours. Then crank the motor over and see if coolant spews out of any cylinders. That will tell you where the problem lies and where to look when you take it apart.
Old Mar 7, 2013 | 08:32 PM
  #14
AlexG's Avatar
how does this help me?
Old Mar 8, 2013 | 05:12 AM
  #15
Since you stated that you have steam from the exhaust after pressure testing that tells me that there is an internal problem that needs to addressed. Doing the proceedure that I told you will make the diagnosis easier once you take it apart since you know which of the 8 cylinders is giving you the problem. You can , of course, try one of the many coolant stop leaks on the market and see if it helps, I just wouldn't consider this to be A perminent repair or the car one I'd rely on for A trip. I'm sure thats not what you wanted to hear , sorry!
Old Mar 8, 2013 | 02:35 PM
  #16
AlexG's Avatar
so it sounds like the head gasket is done or the block is cracked? and your telling me i can get some more miles out of it with a stop leak?
Old Mar 11, 2013 | 05:20 AM
  #17
Its worth A try but no guarantees.
Jimkana
51
Sep 4, 2018 08:22 PM
officerbear
Aug 26, 2016 05:48 PM
Nwodeville76
Aug 19, 2012 10:19 PM
JoerobustoJoesilhavy
Jun 13, 2012 09:24 PM
wrathofdad
Oct 26, 2011 06:47 PM
