1992 Seville Instruments
Had a 92 Eldorado with the same problems; low oil pressure indicator comes on; 223 temp, turn off engine comes on; low fuel comes on. 97,000 miles; been sitting for 2 years. Took off radiator; cleaned @ shop; replaced thermostat. Fans are working good.
Question: heard from some sources that the instrument panel was a problem with the Eldo & the Seville; thinking about using some manual type gauges.........any ideas? Or any comments about the panel?
Thanks John
Thanks John
panel will indicate lo fuel, then will move to full; yet info will indicate mileage range as LO. (car is almost full of gas)
panel will show temp @ 216 up to 223, then states to turn off engine, yet I can can touch the upper radiator hose with my hand; it is hot, but does not feel extreme.
I have heard that the panels are expensive to send off & calibrate; can I go ahead & install quality manual temp & oil pressure gauges?
Thanks Tater
Thanks Tater
