1988 deVille Air Conditioning is bonkers
Old Apr 7, 2012 | 05:28 PM
PARUSSELLdeVille's Avatar
Default 1988 deVille Air Conditioning is bonkers
Hi there. This my first Caddy and my first post. I hope you can steer me in the right direction. I have searched the forum and found no answers.
I have a 1988 Sedan deVille just purchased from the original owner with 94000 miles. The car runs like a swiss watch but has no AC. It is currently unplugged at the compressor to save fuses and the O/O was told that it will require a new compressor.
Here is what its doing. I plugged the wires back into the compressor, started the car, turned on the A/C and it cooled for 2 seconds then blew the 25amp fuse for the AC (the fuel display went dark as well).
Any suggestions?
Old Apr 7, 2012 | 07:27 PM
Cadsforfun's Avatar
Default AC
He must have been told to replace the compressor for a reason. When you get a compresssor, rebuilt or new then you have to replace the ac***ulator and orfice tube as well. That's the only way that the warranty will apply and the system will be squeaky clean. Should cost no more than about $300-$400 if you do the work yourself, but you still have to take the car to an A/C place and get them to evacuate the A/C coolant. Then take it back after the work you do and they will recharge it.
Old Apr 7, 2012 | 09:24 PM
Thanks for the reply. I am always suspect of surgeons and mechanics. I once had a "reputable" shop suggest that I needed to replace my rotted exhaust system on a car that,only the weekend before, had a custom stainless steel system installed.
This car apparently still has the original R12 refrigerant. I understand that converting to R134 is not a simple task.
Thought?
Old Apr 8, 2012 | 02:02 PM
Cadsforfun's Avatar
Default AC
The changeover on mine was quite simple. If you are getting a compressor anyway it will be compatible with the R134 that's used now. You will also require about 6-8 ounces of oil in the system. Most of the compressors will have the option of being switched or unswitched also depending on what you have now.
jla65672
Jul 11, 2011 02:47 PM
justtalkin
Aug 11, 2010 09:39 PM
mainstreetauto
May 6, 2008 12:04 PM
ivanbrum
Jun 24, 2007 08:13 AM
rhayes525
Apr 18, 2007 05:39 AM
