1976 eldo engine issue
1976 eldorado 500ci fuel injected. I have changed distributor module & spark plugs, checked for fuel presure at rail (40 psi) I have spark, have 12 volts @ coil, but dont know how to check the volts @ injector car runs but only with carb cleaner. I know it is an injector issue but cant seam to know how to check them. please help I am getting fustrated with this dam car.
It would be better to continue previous thread, but oh well. Do you have 12v at injectors? There is a tool called a "noid light" (injector test light) it can be plugged in to injector connector. It should blink as engine turns over. Check all 8, respond to this thread.
haaseman
Jan 13, 2009 08:18 PM
420Deville
Nov 10, 2007 07:06 PM
jaustin
Oct 25, 2007 10:09 AM
