1971 Fleetwood seat motor
Old Aug 5, 2016 | 08:11 AM
Mr108's Avatar
Default 1971 Fleetwood seat motor
My passenger seat motor just clicks with no seat movement help please!
Old Aug 5, 2016 | 11:51 AM
because of the age of the car broken wires are not uncommon, particularly if switch is on door. The click is probably the transmission solenoids. The motor should be attached to transmission under seat it will have a 2 wire connector with a test light see in lamp will light when connected across connector. The relay is also mounted to seat frame 2 connectors one for motor the other for switch. Unfortunately I do not have wiring diagram to give you colors. The Power seat motor draws alot of current and tended to overheat connectors. You need to probe connectors to see what is getting voltage. It's a start.....
GTOken
Nov 20, 2011 03:57 PM
GeoffKate
Jan 23, 2009 08:20 PM
OBrien
Jul 26, 2007 07:23 AM
legalz
Mar 8, 2007 10:15 PM
