relays
Old Jun 5, 2018 | 04:22 PM
gnf_farr@yahoo.ca's Avatar
Question relays
Where are the front fog lamp and parking assist relays located on 2011 SRX? Neither of these are working and I am trying to trace problem.
Old Jun 9, 2018 | 11:27 AM
Vinn's Avatar
Default dash board lighting problem
i have an 88 coupe de ville. i posted a problem with "no lights at dark" on the transmission window. i found it to be the headlight reostat corrosion. it would be an easy fix if you could reach the back side of the dash! it is easer to cary a flash light, "let the new owner" fix that too. vin
Old Jun 10, 2018 | 04:14 PM
2011 doesn't use rheostats. Electronics.
Old Jun 11, 2018 | 07:25 AM
Vinn's Avatar
the rheostats are at the high amp items. like headlights or horns. their switches are low amp..(pre computer electronics) 1988
Old Jun 13, 2018 | 08:27 AM
Vinn's Avatar
Default air ride signal sender location.
for the 1988 caddy, it has an air compressor connected to the battery (by passing the ignition switch). it posts a signal to the dash "leveling" even when the car is parked. does it need a new sencing device? vin
Old Jun 13, 2018 | 08:29 AM
Vinn's Avatar
Default relays not reostats.
sorry. vin
EconProf
Jun 28, 2018 01:29 PM
Vinn
Jun 4, 2018 08:44 AM
hgoodwiniii
Mar 6, 2018 08:02 AM
jaboyer34
Feb 3, 2018 06:58 PM
hgoodwiniii
Oct 3, 2012 08:08 AM
