relays
Where are the front fog lamp and parking assist relays located on 2011 SRX? Neither of these are working and I am trying to trace problem.
dash board lighting problem
i have an 88 coupe de ville. i posted a problem with "no lights at dark" on the transmission window. i found it to be the headlight reostat corrosion. it would be an easy fix if you could reach the back side of the dash! it is easer to cary a flash light, "let the new owner" fix that too. vin
2011 doesn't use rheostats. Electronics.
the rheostats are at the high amp items. like headlights or horns. their switches are low amp..(pre computer electronics) 1988
air ride signal sender location.
for the 1988 caddy, it has an air compressor connected to the battery (by passing the ignition switch). it posts a signal to the dash "leveling" even when the car is parked. does it need a new sencing device? vin
relays not reostats.
Originally Posted by gnf_farr@yahoo.ca
(Post 55067)
