differential gear oil
Old Feb 16, 2012 | 10:16 AM
iputon's Avatar
Default differential gear oil
i have a 1985 seville 4.1 motor front wheel drive what type of oil to put in the differential thanks
Old Feb 16, 2012 | 12:14 PM
Cadsforfun's Avatar
Default Oil
Use SAE 80 or SAE80-90 GL5 Gear Lube Some GM#1052271 or 1052272. Recommended change every 10,000 and check level once a year.
Old Feb 21, 2012 | 01:58 PM
Henry Leland's Avatar
Why so often? Just because it's front-wheel drive and runs hotter? For rear differentials changing the oil every 100K miles is usually more than often enough.
Old Feb 22, 2012 | 11:47 AM
Cadsforfun's Avatar
Default Diff. Oil
Just from the GM maintenance charts, not something that I recommend. I agree that it is too often as well and never do it more often than about 50,000. All depends if you have been towing or not.
Macko11586
Jun 16, 2009 10:40 AM
1mpalaSS
Dec 11, 2008 07:03 PM
douglascase
Aug 5, 2008 09:37 PM
cadillacpete
Feb 13, 2008 05:34 AM
