differential gear oil
i have a 1985 seville 4.1 motor front wheel drive what type of oil to put in the differential thanks
Oil
Use SAE 80 or SAE80-90 GL5 Gear Lube Some GM#1052271 or 1052272. Recommended change every 10,000 and check level once a year.
Originally Posted by Cadsforfun
(Post 43998)
Diff. Oil
Just from the GM maintenance charts, not something that I recommend. I agree that it is too often as well and never do it more often than about 50,000. All depends if you have been towing or not.
