Need help Tried everything 1993 sedan deville owner
Old 06-13-2017, 11:00 PM
DanGodley's Avatar
Default Need help Tried everything 1993 sedan deville owner
My car runs great for the first ten to fifteen minutes after starting after that it runs like crap , it misses, backfires , and dies all the time. I've replaced all sensors new plugs and plug wires , new distributor , repaired all bare wires, I've checked everything repair manual said to check and it still only runs good for the first 15 minutes. Can anyone tell me what the problem cold be because I'm ready to buy a PCM and PROM out of a car at a wrecking yard , same year and model and if I do can I just remove from one car and install into my car or does it have to be programmed first?
Old 06-14-2017, 07:31 PM
Do you has FSM? Codes? Distributor has to installed with the correct orientation be cause it has cam sensor. It is wrong injectors will pray at wrong time. Ground wires clean on not painted bolts/studs. Check egr make sure valve isn't open.
Old 06-18-2017, 08:12 AM
dedgar's Avatar
lasmith03
06-25-2014 10:45 AM
syzygy
10-08-2011 05:33 PM
bobfeder
05-10-2009 10:25 PM
nyblonde2004
05-19-2007 03:13 PM
Katzmans Caddy
04-15-2007 04:25 PM
Quick Reply: Need help Tried everything 1993 sedan deville owner
