Seized Spark Plug Northstar Engine
Old 04-17-2018, 11:00 AM
gingerkbrown35's Avatar
Question Seized Spark Plug Northstar Engine
Good Morning to All,
I have an 2005 Cadillac Deville with a V8 4.6 L Northstar engine that has around 85,000 miles on it. The mechanic is pulling code of a misfire at the 3rd cylinder, but is reporting he cannot remove the spark plug to make the repair,as it is seized. I am reaching out to see if anyone has come across this situation and could give us some direction....it would be greatly appreciated.
Thank You,
Ginger
Old 05-12-2018, 08:28 AM
Vinn's Avatar
Thank You,
Ginger
seized spark plug occurs often on older engines. don't force it, it will strip the threads. I suggest squrting penetrating oil (not wd 40) near the plug base an run it till hot - try again. vinn
gingerkbrown35
04-17-2018 10:52 AM
SLScaddy
11-27-2012 10:49 PM
06-05-2007 07:10 PM
goldseal
06-04-2007 04:30 PM
michaeldkania
09-18-2006 11:45 AM
Quick Reply: Seized Spark Plug Northstar Engine
