BAD THEFT DETERRANT MODULE
Old Nov 30, 2007 | 09:29 PM
stoney1113's Avatar
Default BAD THEFT DETERRANT MODULE
I own an '89 Eldorado Biarritz that hsas an dad theft deterrrant module. I've chech ever Salvage yard with in 50 miles of where ?I live and can not locater one. I would like to know if anyone out there can tell me if there is a way tro bypass the anti thefth on my car. Righ now I can not afford a new module. A friend of mine put in a different computer tso I ciould start the car but nothing else on the instiment pannle works now. Can the theft deterrant module be by passed>
[/align]
Old Nov 30, 2007 | 10:13 PM
Default RE: BAD THEFT DETERRANT MODULE
Theft deterent modules don't go bad very often and you have a 1 in 17 chance of getting a good one that will work in your car. What makes you think module is bad?
Old Dec 1, 2007 | 06:12 AM
stoney1113's Avatar
I am not sure if the deterrant module is bad. I took the car to a guy I know who is good with cars and he told me the theft deterrant module was bad. All I know is that he did some work on in the sterring collom pryer to that and noticed that the two little wire that run to the ingition switch were broke. He said the wires were for the anti theft and that the car should not even start. I drove the car home that day and later when I tried to start it it whouldn't evern turn ove. The computer told me that starting was disabled ans told me to wait three minute and then start the car. When I did that it just kept repeating the same thing. The guy came and towed it to his shop and later called me and told me it was the deterrant module. I don't know what he did to it to get it running but now none of the other funtions work
[/align]
Old Dec 1, 2007 | 09:22 AM
Broken wire(s) is why car won't start, you need ignition lock cylinder not module. Ignition cylinder and new key will run about 100.00 and labor 1.0-1.5 hours. You will need to go to dealer to get old key read and new key made. It sounds like your friend should be able to repair.
Mike Sentner
Dec 11, 2014 03:50 AM
mint93deville
Dec 1, 2014 07:46 AM
astrodan13
Aluminum Block V8s
Jun 14, 2011 12:24 AM
Chris90Deville
Sep 20, 2010 07:18 AM
Mar 3, 2008 10:14 PM
