air suspension
Old Sep 6, 2008 | 06:37 PM
mjd's Avatar
mjd
Default air suspension
Hello I have A 1984 Cadillac Eldoroado Biarritz convertible and I recently replaced rear air shocks and it seems the car is not lifitng properly passenger side tire is rubbing I am thinking maybe I need a new air ride sensor any thoughts and where can I find this part? Thanks
Old Sep 7, 2008 | 12:05 PM
Katzmans Caddy's Avatar
Default RE: air suspension
Are all of you lines new as well. Any leaks?
Old Sep 7, 2008 | 02:23 PM
carnut's Avatar
The level ride sensor is above the passsenger side rear suspension. Disconnect the sensor link that attaches to the lower A frame ( pops off with a large screw driver) and with key on, car off, raise that link up. Within 30 seconds you should hear the under hood pump run and watch your shocks inflate. If not then you need to confirm voltage is present at the plug on the sensor. If voltage is present then, yes, replace the sensor. Tires rubbing? you must have wider than stock wheels. There is also a air filler port on the pump itself. You can add up to approx 75 LB and verify the air lines are holding. Do you ever see the green level ride light in the info center??
Old Sep 7, 2008 | 04:10 PM
mjd's Avatar
mjd
Thanks I will try tips if I need sensor where can I purchase? also just replaced tires and wheels installed 15" daytontruspoke wheels and vogue tires same size replacement tire as original. The gren level ride light was coming on then off again a few times.
Old Sep 7, 2008 | 04:11 PM
mjd's Avatar
mjd
No did not replace lines.
Old Sep 7, 2008 | 05:44 PM
carnut's Avatar
If the green light came on, then the sensor and supply pumpare probably OK. I think you have an air line leak. Did you install factory DELCO shocks? Your wheels are wider than the factory wheels, thats why they rub. The rear suspension is designed to always have at least 20 LB in the shocks.
strabo40
Mar 12, 2010 11:43 AM
eight_05_south
Jul 8, 2009 01:26 PM
miaustin
Apr 28, 2009 11:55 AM
ajax68960
Jan 25, 2008 08:17 PM
kevinknapp1978
Oct 15, 2006 02:34 AM
