sticky shifter
Old Jul 2, 2008 | 05:23 PM
codye06's Avatar
Default sticky shifter
I just bought a 98 STS and when i try to take it from park to anything it is hard to get it to cooperate. after messing with it for a few minutes it will finally "click" then it will work perfect. the guy at the dealer said it was something to do with a silenoid that is supposed to activate when you step on the brake. he also said sometimes if theif is coffe or coke that has been spilled on it that can cause this. i was going to try to fix it myself since it sounds like it may just need cleanning but wanted to ask if any body else had done this before? will i have to remove the entire dash to get the console off to expose this silenoid? any help would be appreciated.
Old Jul 2, 2008 | 09:10 PM
Katzmans Caddy's Avatar
Default RE: sticky shifter
Why not try spraying some WD-40 in there. It won't ruin electrical parts and it has some cleaning capabilities too. Just a suggestion trying to save you a big hassle
Old Jul 2, 2008 | 10:14 PM
codye06's Avatar
i will give that a shot but just incase do you know if it is a relatively simple process to take off the center console?
Old Jul 2, 2008 | 10:51 PM
Shouldn't be too hard, start by looking in compartmemt for mounting screws to floor. Don't force anything.
STSSCOTT
Mar 29, 2019 08:57 PM
jnrsesv
Feb 15, 2010 09:09 PM
Hardrive
Jan 29, 2008 06:19 PM
Dockterj
Nov 29, 2005 11:45 PM
simjack
Jan 9, 2005 10:04 AM
