98 sts electrical cvrss and radio
Old May 31, 2011 | 10:39 PM
Hookin1's Avatar
Default 98 sts electrical cvrss and radio
I have a 98 sts just bought, upgrading from a 91 deville.
Anyhow the car has a eletrical problem. I disconnected the negative cable put my test light between the ground cable and the ground on the battery. chased circuts for a while and found a 3 amp draw on the cvrss fuse. disconnected the cvrss module and the battery stays up.
Now the question is do i replace the module or is there something else that could be drawing the battery down but it not be the module defective? The compressor is not running when the key is off.
The other question is the radio (it has the bose system with cd changer) it works with a tape and on am but on fm it really bad reception and static. Also where can i get the cd cartridge for the changer?
Old Jun 1, 2011 | 09:41 PM
gmtechs's Avatar
first question did u wait 20 minutes to take your reading, it takes about that much time for all modules to power down.
Old Jun 2, 2011 | 07:42 PM
Hookin1's Avatar
yes i did.
Old Jan 15, 2012 | 01:15 PM
Hookin1's Avatar
Update...Replaced cvrss module took care of battery drain.
jfro
Jan 9, 2014 08:46 PM
lraguz
May 2, 2008 08:34 AM
Oct 20, 2007 07:59 PM
AllCaddys
Oct 10, 2006 12:20 AM
