'97 Cadillac STS Z-rated option
Old Nov 11, 2007 | 11:14 AM
Default '97 Cadillac STS Z-rated option
ORIGINAL: foxpaws
Wow - one of my favorite big boy Caddies... You have a great sleeper there.
And black - best color
In '97 there was a Z-Rated option - one that took the governors off the engine so it could go well above 150, had Z-rated tires, a stiffer suspension programming, a different torque converter and 4l80T setup so the car can switch into 4th gear at wide open throttle and lock the converter up under full power, and a bit larger cooling system so you can stand on it. Sort of pre-"v" series. It would allow you to see almost any stock corvette in the rear view mirror...
Oh, tell me you have that....
Although - most of those were sold to the European market - I think very few in the US.
If not - first thing I would do is take care of the exhaust and intake - although, you probably have sensors on the cats - so you might have to do cat-back only, or check with Magnaflow and see if they have a work-around on the cats.
Also - I know they have chips for the engine - although - I am still waiting to hear from someone to see how his chip worked on his northstar - he had it dyno'd before - but hasn't gotten it dyno'd since the change out - these are de-tuned racing engines, and changing the programming should help them a lot.
Post photos... please.....
Fox,
how does one tell if an '97 STS is one of these?
I bet they are big time sleepers and people dont even know they got them.
Old Nov 11, 2007 | 12:48 PM
foxpaws's Avatar
Default RE: '97 Cadillac STS Z-rated option
Unless you know it has original tires (I hope it doesn't anymore) I am not sure - one of the techs at work talks about these all the time - he was a tech for GM at the time these came out - and loved them.
eBay has one in Canada...
http://cgi.ebay.ca/Cadillac-Seville-...QQcmdZViewItem
But - it needs headgaskets - not cheap - sort of the Northstar curse if you don't take care of the coolant...
See if you can take it over the stock 130 speed limiter - If you see 150 as you merge into traffic you can be assured you have the 'z' package
Old Nov 11, 2007 | 01:15 PM
Service Part IDentifaction label - SPID for short. GM puts SPIDs on all cars and trucks since the early 80s.Its like a build sheet. Its location varies from model to model. Spare tire cover and under side of trunk lid most popular in cars. RPOs QVF 225/60ZR16 blackwall tires. NC7,NB8, or NG1emssions export or overriden. T84 or T85 head lamps.I would expect to see these on SPID label.
cbrc5eric
Apr 21, 2016 06:22 PM
STS GUY
Apr 11, 2015 06:23 AM
shoreholden
Jul 4, 2011 04:01 AM
rahoyme
May 2, 2008 11:49 PM
ryderctsv
Nov 22, 2005 12:24 AM
