2000 Cadillac STS; sunroof fuse #20 & service stability system
Old May 14, 2009 | 11:29 PM
dkainsworth's Avatar
Default 2000 Cadillac STS; sunroof fuse #20 & service stability system
I have a 2000 Cadillac STS, and I am having problems with my sunroof. I had it open one day the I shut it and from there it has not worked anymore. I have checked for fuse and a relay and for some reason I do not see anything pertaining to a sunroof. I even called the dealer and they could not find a fuse or a relay for this car. And, I also have another problem. My computer reads service stability system and suspenion. It also says speed limited to 90 mph. Can someone please help me?
mod edit
title
Old May 15, 2009 | 09:58 AM
i assume the power roof is factory, and not aftermarket. if so, check your fuse #20..... see if that is ok..... let us know....
as for your sss read, the forum would like codes to assist your issue
Old May 15, 2009 | 03:41 PM
92_Daddylac's Avatar
That means either your struts or air compressor are bad. So the car is not safe to go over 90mph. Have that checked out that will cause allignment issues and tires will not wear properly. Let us know what you come up with.
Old May 15, 2009 | 06:00 PM
rickyd right about now, you are my hero! I have taken my car to the shop two times for my sunroof and no one else knew about fuse #20. I replaced the fuse and guess what you helped me fix my problem. Thank you!!!!
Old May 15, 2009 | 06:04 PM
Default response
Thank you Mr. Daddylac, I have noticed that my tire do wear on the inside. And, each one of my tires are about $300.00 and I am so tired of replacing them. I will have my struts and air compressor checked next week.
Old May 16, 2009 | 01:27 AM
i had replaced my rear struts my self wich is very easy (1/2hr-1hr max) if you have basic mechanic tools. No allignment is needed so dont let ppl tell you different. If you have questions let us know.
Old May 16, 2009 | 06:27 PM
dang, go figure..... i did get something right..... keke serious, glad to hear, and thanks for getting back
Old Mar 1, 2020 | 12:02 PM
Fred's Avatar
Default Sunroof trouble
Hi Where is this fuse number 20 ? Thanks for reply !
Old Mar 3, 2020 | 02:21 PM
KRDCAD's Avatar
Read your owner's manual
Serenity1990
Oct 25, 2016 09:16 PM
Flye
Aug 10, 2014 08:19 AM
2000devill
May 17, 2013 01:54 AM
bonecus
Jul 12, 2007 07:13 PM
cadirydin
Dec 3, 2006 08:06 PM
