1999 sts hard start problem
Old Nov 4, 2006 | 10:09 AM
stelling's Avatar
Default 1999 sts hard start problem
i have just purchased an 99 sts after the car is warmed up and hot it is hard to restart have to spin over at least 6 times before it will fire i have noticed when it is just half warm according to the gauge it is easier to crank it is as if it is not gettin any fire does not to seem to be a fuel problem crank or cam sensor maybe??
Old Nov 4, 2006 | 11:06 PM
FLCaddytech's Avatar
Default RE: 1999 sts hard start problem
Have it scanned.
Crank sensors are common problems.
Fuel pressure regulator leaking down is another, but more so after sitting for a while( 15- 30 minutes)
Old Nov 21, 2006 | 01:59 AM
hagrid's Avatar
Yep the most likely culprit would be the crank sensor. I would also suggest that another thing to inspect would be the distributor itself.
Old Nov 21, 2006 | 02:14 PM
No distributor on a Northstar.
Old Jan 5, 2007 | 01:53 AM
cadillac1999's Avatar
regarding hard start. my 1999 sts had the same problem. after replacing fuel regulator the problem was resolved. fuel regulator cost about $40.00, was easy to replace with basic tools, its found under cosmetic cover on top of intake manifold
Gumby
Jan 11, 2014 09:35 AM
jps2000
Aug 12, 2010 08:58 AM
bidness97
Mar 1, 2006 02:52 PM
bidness97
Nov 23, 2005 04:54 PM
