06 STS Navigation problem
Old Feb 11, 2010 | 02:22 PM
jarektf's Avatar
Default 06 STS Navigation problem
Hallo everybody. I've got problem with my navigation unit. There is on the screen information: "CAUTION, cannot load System Software.
Disk type incorrect. Please insert correct System disk". No nav, no cd, no car menu. I've got original dvd PN 15924195, but it doesn't boot. Maybe you know where can I find the software disc? Thanks
Old Feb 11, 2010 | 10:39 PM
jono6406's Avatar
Wink
Check ebay.They have lots of disc's at different prices and/or different versions.
ok as far as I know these will work in your STS.
1.0V.....PN#10381281.....05 DISC
2.0V.....PN#15794606.....06 DISC
3.0V.....PN#15924195.....07 DISC
4.0V.....PN#25852830.....08 DISC
5.0V.....PN#25976806.....09 DISC
All of the above disc will work in the STS'. It just depends on what version you get. The later the version the more updated the info/POI.
Looks like you have the correct disc...maybe its bad or the nav unit is bad or needs to be rebooted?
Old Feb 12, 2010 | 05:14 PM
jarektf's Avatar
Thanks for the answer. I've got the original disc with the maps, but I need firmware cd. Probablly it's two CDs only with firmware.
Old Sep 29, 2011 | 05:55 PM
dking's Avatar
Default Same Nav Problem
Did you ever get your Nav issue solved? My '05 Nav is doing exactly what yours did. Need some kind of firmware upgrade. Thanks in advance.
STS'ter
Apr 20, 2010 04:03 PM
trakspeed
Jul 4, 2009 06:45 AM
caddi02dts
May 27, 2009 11:37 AM
israel_davis
Dec 30, 2007 01:23 PM
israel_davis
Dec 30, 2007 09:20 AM
