Cadillac SRX The SRX offers the versatility of a mid-size sport utility vehicle with a sports car feel
04 SRX Tires and Wheels
Old Oct 12, 2006 | 11:34 PM
frank0807's Avatar
Default 04 SRX Tires and Wheels
Hi,
Past viewer of this forum, but have not been around for a while. My question is: I have a 04 SRX V6 with the stock wheels and tires with pressure monitoring. Not sure what the problem is. I live in the Chicagoland area, so you know what the weather is like. Anyway, when the air temperature changes about ten to fifteen degrees the air pressure in the two of the tires drops about ten pounds. The monitoring system detects the pressure lose and notifies the driver via the info center. Have anyone seen anything like this. Not sure if it is the tire or the wheels. Any information will be helpful.
Thanks in advance...
Frank0807
Old Oct 13, 2006 | 08:12 PM
FLCaddytech's Avatar
Default RE: 04 SRX Tires and Wheels
this is the time of year we reset tire pressures that were adjusted during the summer.
Colder overnight temps cause lower pressure which triggers your light.
We see 5 - 10 cars with your concern right after our first cold snap(not all that cold compared to you)
Old Nov 30, 2006 | 09:48 PM
bigsoundof's Avatar
I have an '04 SRX as well (V8) with 18" tires. Does anyone know if there would be a problem with downgrading to 17" wheels and tires. 18's are pretty pricey and wear out quickly.
Old Feb 28, 2008 | 05:32 AM
ucyiwork's Avatar
I thought it was common knowledge that Tires loose a bit of air when it is cold and gain a bit when it is hot. Check the pressure once a week to keep in check and save yourself a little gas in the end.
GTA17
Jan 8, 2009 08:03 AM
mjd
Eldorado Biarritz
Sep 10, 2008 05:26 PM
caddy96
Jul 26, 2008 12:10 PM
InfraredV
Jan 23, 2008 05:36 PM
MGRXXX
Jan 14, 2007 08:46 PM
