xenon replace
Old May 20, 2008 | 01:42 PM
blazes's Avatar
Default xenon replace
i got a head light burn and i whant to replace it my car is 2003 seville sts with factory hid someone no how to replace it i just got my new buld and if you have pics how to do it .....
Old May 31, 2008 | 11:44 AM
Feuerhose's Avatar
Default RE: xenon replace
It should be easy to replace a bulb. To pull the plug off, you may have first to turn it then pull it off. the lamp has to be turned some degrees to release it or you have to release a spring or something to take it out. you should rememer how the lamp was inserted, cause you have to put the new one in the same position as the old.
EDIT: When you have xenon lights, it's very important to turn the lights off before working on it. That's high voltage!
classiccars
Aug 12, 2011 02:42 PM
cirrgang
Jun 10, 2009 10:47 PM
xmguyx22
Nov 6, 2008 08:10 PM
tncadillac96
Dec 11, 2007 01:05 PM
bwickes
Oct 16, 2006 12:07 AM
