Buttons and switch lights-Repair\Replace?
Old Jan 17, 2007 | 11:06 AM
cirrgang's Avatar
Default Buttons and switch lights-Repair\Replace?
I have 2001 DeVille. Lights under buttons and switches are starting to burn-out, one at a time. I thought these would be fiber-optic to common light source, but evidently not. Now have lights out under one seat heater button and the INFO button. How are these accessed and replaced, pry the button off or remove panel?
Thanks.
CIrrgang
Old Jan 18, 2007 | 01:46 AM
misfit6794's Avatar
Default RE: Buttons and switch lights-Repair\Replace?
I wouldn't pry on anything, you can most likely access the lights through the back of the panel. Check your fuses, its weird to blow all those lights almost at the same time.
Old Jan 25, 2007 | 12:12 PM
cirrgang's Avatar
Thanks for the reply Misfit. Not all of the lights are out, just a fewof the buttons. Just lost another,the one behind the display "eng\metric" button. I expect there are littlebulbs behind the buttons or integrated with the buttons. I just don't know the best way to get to them. The buttons are clustered in small panels that are inset in the larger dash. I'm going to try removing one of those small insets and see what happens.
Old Jun 10, 2009 | 10:47 PM
CaddyJohn's Avatar
Not sure fuses are the problem... That would mean that the device itself would not work. Plus, a unit with three buttons, like the one to the right or left of the instrument pannel, having one of two dead bulbs is simply an indication that the bulbs are shot. I have the same issue with my 2002 Deville. Some of my lights are burning out on random buttons, some I rarely even use. They are a very small diode-sized bulb with two little connectors. I know they were replaceable on an Oldsmobile Eighty Eight I had, but I'm fearing that these are closed units on the Cadillac. That is, you cannot access them.
I can imagine the dealership can get these little bulbs, if they are replaceable. So I will report back on how that goes over. I can certianly understand wanting to change them, it's very annoying when they are lit or not lit spratically.
CadillacAttack.
Eldorado Seville
Dec 30, 2013 09:16 PM
carcesr3
Mar 17, 2011 03:09 PM
jerryb
Sep 23, 2009 11:14 PM
dimitri94seville
Jun 21, 2008 12:53 PM
tncadillac96
Dec 11, 2007 01:05 PM
