Traction Control Disabled, help.
Old Apr 27, 2007 | 03:42 AM
Afterburn's Avatar
Default Traction Control Disabled, help.
Whenever I turn on my car, it says that my traction control is disabled. I checked the codes and the only one I get is P029 which is for my faulty Shift Solenoid.
Old Apr 27, 2007 | 05:32 AM
belagatyo's Avatar
Default RE: Traction Control Disabled, help.
My '97 has a button in the glove compartment which can turn on or off TC.
Old May 9, 2007 | 01:24 AM
Katzmans Caddy's Avatar
I believe that every time the car is turned off the default setting is invoked and I believe that the default is Traction On. It would seem that if hitting the override button does not invoke Traction Control then some problem persists. Traction control relies on the ABS system but is seems odd that you have no codes for that. Is your ABS working properly?
Adrian_407
Jun 21, 2011 04:08 PM
Adrian_407
Jun 18, 2011 11:53 AM
marcus88
Sep 15, 2008 08:19 AM
TDL
Nov 27, 2007 07:18 AM
ezgoin_1
Jun 5, 2007 02:43 PM
