Radio/ Climate control/Instrument cluster lights flash constantly
Old Sep 14, 2009 | 10:09 AM
marklar's Avatar
Default Radio/ Climate control/Instrument cluster lights flash constantly
Ok,
The car... 2000 seville sts, The problem.... All interior dimmer controlled lights on the dash are flashing constantly. The flashing is not equally timed, it's inconsistent yet constant. I have checked the connections on all of the following... Fuses/relays/dimmer switch I also disconnected the battery thinking it could be a security system malfunction, but no luck. No codes are present, which just baffles me. So has anyone else had a similar issue, and what could be the culprit of this problem?
Old Sep 15, 2009 | 07:11 AM
just a question for you.... does the fuel gague work properly?? if so, have you considered changing the headlight switch it-self?? i think id start there. do you have the stuff to check the switch?? IMO switch. now if there are other electrical issues running wrong, then let the forum know....
oh welcome to the forum check in with member intro if you havent.... c u round
montemann
Jan 13, 2007 10:23 PM
prairecwby
Nov 29, 2006 05:20 PM
dubz01
Oct 26, 2005 06:42 PM
toms46
Nov 21, 2004 05:10 PM
