Problem with road suspense system
Old Jun 19, 2007 | 02:11 PM
Feuerhose's Avatar
Default Problem with road suspense system
Hi,
I have a Seville STS '92 4.9L, export version. It has some problems wich maybe belong to each other.
Firstproblem:When I turn ignition on, the air compressor in the rear begins towork, but doesn't stop for 7 minutes. I've read, it could be because a leak in the system.
The second one: At theinformationcenterapears "SERVICE RIDE CONTROL".
And the third: In the Onboard Diagnostics System appears the error code "I039 CURRENT" wich means "Loss of Road Sensing Suspension Data".
Please help if anyone knows something about this!
Thanks
Old Jul 5, 2007 | 06:25 PM
cookena69er2's Avatar
Default RE: Problem with road suspense system
Theres sensors located on each of the shocks, it sounds like one of them has gone bad or the shock itself is bad. Problem is you can't just buy the sensor you have to replace the whole shock. I got all my shocks from Arnott Ind. Well i hope that helps a little.
Old Jul 27, 2007 | 01:54 PM
askim's Avatar
I have had the IO39 error in my 93 seville for a while now. i know what the message is and what is causing it but this is my question.
Do I have to go back to the same kind of shocks or can I swap them out for a passive system. And if yes, Then can anyone recomend what I should use?
Thanks?
Old Jul 27, 2007 | 04:23 PM
Chrisfor172's Avatar
I get a service ride control on my 94 seville too. I think it's just the rear. But I saw something on this page that sells passive shocks. I'm thinking of trying them.
Old Aug 9, 2007 | 01:57 PM
Feuerhose's Avatar
Thanx for the help. CanI Test the sensors by myselfwith the onboard diagnostics or other,or do i have to visit the dealer?
jadondarling
Jul 29, 2007 03:44 AM
DrugFreeMAn
Jul 27, 2007 07:33 PM
Jul 20, 2007 05:14 PM
Jun 29, 2007 09:19 AM
cadillacman777
Apr 3, 2007 10:16 PM
