PREMIUM GAS
Old Jun 22, 2006 | 09:55 PM
DEEBEE's Avatar
Default PREMIUM GAS
WITH THE HIGH PRICE OF GAS THESE DAYS I WAS CONSIDERING USING REGULAR OR MID GRADE GAS TO SAVE A FEW BUCKS. IS THIS A BAD IDEA OR COULD IT DAMAGE THE ENGINE? THANKS !!
Old Jun 22, 2006 | 10:21 PM
FLCaddytech's Avatar
Default RE: PREMIUM GAS
Take it easy on the car and it will be ok. If you hear it knocking under accel (hot days are worse) switch to a higher octane.
Old Jun 23, 2006 | 12:49 PM
VetteViperGuy's Avatar
This is what I have heard: If your car manufacturer recommends 91 octane, you can still put in 87 octane gas, and it won't hurt the car. The onboard computer will compensate the timing and the engine won't knock. The only "adverse" affect to filling up with regular gas, instead of premium, is that you won't make all the power that your can with premium gas.
For my Vette, it's only premium gas. For the 'Lade, I've never tried regular gas, but it's just because I'm so accustom to pushing that "premium" button....they've got me programmed....
Old Jun 23, 2006 | 08:19 PM
ORIGINAL: VetteViperGuy
The only problem with lower octane is knock happens before the computer pulls timing. The older cars (pre 00 or there about) are not as good at protecting an engine from knock, so keep an ear open when you step on the throttle. If you can hear it, its pretty bad.
Not saying its gonna blow up the first day, but i've cracked pistons twice in my boosted 4banger by not running 93.[:@]
Old Jun 24, 2006 | 01:53 AM
DEEBEE's Avatar
THANKS FOR THE INFO, BUT MAYBE I SHOULD HAVE SAID THAT I AM TALKING ABOUT A 95 SEVILLE SLS WITH 100K MILES. I HAVE ALWAYS USED PREMIUM AS SPECIFIED. I LOVE THE VEHICLE AND DON'T WANT TO HURT IT BY USING A LESSER OCTANE FUEL...JUST THOUGHT I COULD SAVE A BUCK OR TWO UNTIL GAS PRICES COME DOWN AGAIN AT THE END OF THE SUMMER. ( IF THAT HAPPENS )
Old May 17, 2008 | 07:29 AM
greezy1's Avatar
use 35lbs of air in tires that will save gas
Old May 17, 2008 | 10:13 AM
ORIGINAL: greezy1
will also give you better traction.
I go 36 to 38 psi
but the ride will be a bit stiffer.
Old Jun 20, 2008 | 05:58 PM
SwampeastMike's Avatar
"Premium Required" at the fuel gauge isn't there for nothing. Add older car with low miles that you "love" and have always used premium tells me that you should continue.
Old Jun 21, 2008 | 05:43 PM
G.A.R.Y.'s Avatar
ORIGINAL: SwampeastMike
i agree that "premiun required" always use the highest octane.
"Premium recommended" you can use a lower octane with no damage to the engine and the knock sensor should take care of the rest.
Old Jun 21, 2008 | 06:35 PM
thewood's Avatar
Is it really worth saving a fewdollars now and paying thousands of dollars later on engine repair? Think about it and do the math. IMO it doesn't make any sense.
