Normal Northstar Coolant Temperature?
Old Jul 25, 2006 | 01:42 AM
tn350's Avatar
Default Normal Northstar Coolant Temperature?
I have a 94 sts that runs at about 220 degrees in the summer and i was wondering is that the normal temperature or is mine running too hot. i completely flushed out the coolant and replaced it but it still runs at 220.
Old Jul 25, 2006 | 07:31 AM
FLCaddytech's Avatar
Default RE: Normal Northstar Coolant Temperature?
Yup, that should be fine.
Old Apr 6, 2007 | 03:32 AM
chasetoy's Avatar
my car tried to overheat the other day due to some leaks in the cooling system, got upto 248 degrees. Is my engine ok, or could this have cause damage? now the car runs 196-213 sometimes going upto 230 degrees. Also is 230 degrees ok???
any help is very much appreciated thanks!
Old Apr 6, 2007 | 03:37 AM
how can we help unless you give details, car model, engine, year, detailed problem?
of course damage is always a possibility in any engine that overheats,
read this:
https://www.cadillacforum.com/m_6258/tm.htm
ORIGINAL: chasetoy
Old Apr 9, 2007 | 11:42 AM
belagatyo's Avatar
It's a '97 STS, he's opened a new thread for this.
Fortunately the NS has the "Limp Home" feature, so I doubt that that temporary surge in temperature caused any major damage (which does not exclude any pre-existing damage). I'd change the oil though.
I do not even attempt to follow the Dexcool saga, it makes me dizzy. I know that FSMs do have errors in them but figured that I am on relatively sound ground if I follow their recommendations (that and read the TSBs).
ILIAS6571
Feb 9, 2010 12:18 AM
cady97dev
Aluminum Block V8s
Mar 20, 2009 08:10 AM
omidscadillac
Jun 20, 2008 07:23 PM
