Install Sirius Antenna
Old Jun 25, 2006 | 10:52 AM
house1000sleeved's Avatar
Default Install Sirius Antenna
I purchased a 2002 Cadillac STS 4-door, and recently removed my antenna that I installed in my 04' Honda Civic 4-door. I was wondering what the best way is to go about installing the antenna in the cadillac... I started by setting the antenna on the trunk and running the wire behind the trunk lid board and have it running down behind the trunk lid arm(behind the plastic cover) and running behind the trunks interior board on the passenger side. Now I am stuck because I can't find a way into the cadillacs cabin. Any Suggestions?
Old Jun 25, 2006 | 11:03 AM
FLCaddytech's Avatar
Default RE: Install Sirius Antenna
You should be able to go right under the back seat on the passenger side.
Pull up the back seat and look right where the seat bottom and top meet near the door.
I just did a back up camera in one the other day and thats where i ran the wires through.
Old Jun 25, 2006 | 11:11 AM
thanks... how do you pull up the back seat, I tried feeling down in the seat and couldn't find anything, I also tried to see if the seats fold down but couldn't find anything to release them either
Old Jun 25, 2006 | 11:24 AM
There are two clips (one on each side) that hold the front of the seat down.
About 12 - 18 inches away from each door.
Grab under the front of the seat with both hands, one side at a time and give it a good yank straight up.
If the rear seats are heated you will see a small connector on the pass side that needs to be unplugged before removing the seat bottom from the car.
Also when reinstalling the seat make sure all the belt buckles are tucked up into the seat back so they don't get trapped underneth.
Hope this helps.
Old Jun 25, 2006 | 12:09 PM
Thanks for your help. I ran the wire under the panels on the passenger side and now i am under the front dash passenger side any suggestions on how to run the wire up behind the front dash?
buckey
Dec 5, 2012 08:44 AM
alphonso
Jan 27, 2012 08:08 AM
allciuyt
Jun 9, 2011 04:20 AM
rikrok
Jul 21, 2007 03:03 PM
house1000sleeved
Jun 25, 2006 12:51 PM
